查看: 7758|回复: 15
自己设计的51单片机广告灯
sailing 发表于 2009-9-17 15:28:09 | 显示全部楼层 |阅读模式
分为左移两次  右移两次 闪烁两次  间隔0.2s
#include <AT89X52.H>
#define uchar unsigned char
uchar code led[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0xff,
    0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xff,
    0x00,0xff,0x00,0xff};  //
void delay()  //200ms
uchar a,b,c;
for(a=20;a!=0;a--)
for(b=20;b!=0;b--)
for(c=248;c!=0;c--);
void main()
uchar i;
while(1)
  for(i=0;i<40;i++)
   P0=led[i];  ///P0
   delay();
千里漂 发表于 2009-10-30 19:37:22 | 显示全部楼层
这玩意太深奥了,看不懂啊!
{:1_118:} {:1_118:} {:1_118:} {:1_118:} {:1_118:}
wei52hua 发表于 2009-11-2 14:38:44 | 显示全部楼层
看不懂哦,要努力哦{:1_120:}
cmlucky 发表于 2009-11-8 21:12:19 | 显示全部楼层
很久学习的C语了了..能看懂点...一个  循环   播放字符  应该就是LED灯了..但怎么用就不知道  了..学习....
精益广告 发表于 2009-11-8 23:46:51 | 显示全部楼层
看不懂啊,晕[whitepad]***400;200;400,200;;** m74,24 l75,24,75,26,76,27,76,28 e|********* m64,45 l68,45,69,46,71,46,73,47,78,47,84,49,94,49 e|********* m93,53 l92,54,91,56,91,57,89,58,88,61,86,62,85,63,83,66,81,67,79,69,77,70,74,73,72,74,71,74,68,77,67,77,66,78,64,79,60,79,60,80 52,80,52,79,51,78 e|********* m53,62 l56,62,60,64,62,64,64,66,67,67,70,69,73,70,87,76,98,82,101,83,101,84,99,84 e|********* m41,30 l41,31,42,31,42,34 e|********* m30,48 l34,50,35,51,36,51,37,52,38,52,39,53,39,54,41,54,41,60,37,64,37,65,36,66,35,68,34,68,34,69,33,69,33,71,35,73,35,74,37,74 37,75,38,75,39,76,39,83,38,84,38,85,36,87,35,87,35,88,33,89,32,90,29,90 e|********* m8,89 l30,89,38,90,41,91,129,91 e|********* m146,48 l146,47,164,47,165,48 e|********* m143,66 l147,66,150,65,152,65,154,64,158,64,159,63,160,63 e|********* m154,56 l154,79,153,79 e|********* m148,85 l150,82,153,82,156,80,160,78,164,77,169,75,172,73,174,72,176,72,176,70,177,69 e|********* m185,40 l185,39,186,39,187,38,194,38 e|********* m173,54 l201,54 e|********* m194,56 l194,62,193,63,193,64,192,67,191,68,191,71,190,71,190,74,189,75,189,76,188,78,188,79,187,80,187,81,186,82,186,83,185,83,185,85,184,85,184,86 181,89,180,89 e|********* m200,61 l200,66,199,68,199,81,200,82,201,82,202,84,205,85,211,88,232,88,232,86,231,85,229,81,228,77,227,74 e|********* m247,18 l248,19,248,26 e|********* m244,28 l245,28,249,30,251,30,254,31,275,31 e|********* m243,33 l243,35,244,35,244,37,245,37,246,38,247,38,247,39,248,39 e|********* m270,36 l269,36,268,37,267,37,266,39,263,40,262,41,260,42,257,42,255,44,248,44 e|********* m229,44 l251,44,265,43,273,43 e|********* m242,53 l242,57 e|********* m264,49 l266,49,266,60,265,61,265,62,264,62,264,64,263,64,263,65,262,65,262,66,261,67,260,67 e|********* m249,55 l256,55,259,54,261,54,260,55,258,55 e|********* m248,58 l248,59,249,60,251,60,251,63 e|********* m226,63 l226,66,227,68,227,70,228,71,228,72,229,74,230,78,230,87,232,87 e|********* m240,67 l240,77,241,77,241,78,242,78,242,81,243,81,243,82,244,82,244,83,246,83,250,85,252,85,254,86,257,87,263,87,266,88,283,88,282,84,280,82 e|********* m261,71 l264,71,266,72,270,72 e|********* m284,69 l284,70,285,71,286,71,286,80 e|********* m318,46 l318,45,335,45,335,46 e|********* m327,50 l327,56,325,58,324,61,322,63,320,67,318,69,317,69,317,70,315,72,312,72 e|********* m321,70 l321,82 e|********* m333,68 l333,69,334,69,338,73,341,75,344,78,346,79,347,80,347,81,345,81 e|********* m86,119 l83,124,79,128,76,132,71,137,68,139,66,142,64,143,62,147,62,154,63,156,64,157,64,158,66,160,66,162,68,164,69,166,71,168,73,171,77,174,79,176 83,179,85,180,86,182,88,182,89,184,90,185,91,185,88,179 e|********* m85,146 l85,152,84,154,82,156,81,158,80,159,79,161,77,162,75,164,73,165,69,169,66,171,62,172,57,172,55,171,52,169,50,167,48,166,46,164,44,163,42,161 40,160 e|********* m34,150 l34,149,38,148,42,146,48,145,53,144,60,143,78,142,89,141,97,141 e|********* m103,129 l116,129,116,135,115,137,115,138,111,142,110,142,110,145,114,154,115,158,115,179,111,187,111,188,110,189,107,189,106,187,103,185,100,179,98,177,96,174,95,172 e|********* m96,152 l96,151,143,151 e|********* m162,128 l162,130,163,130,163,144 e|********* m173,131 l204,131,206,132,209,132,209,139,206,142,203,144,201,144,198,146,195,147,189,147 e|********* m181,136 l181,146,180,147,180,150,179,151,179,153,178,153,177,154,177,156,176,156,184,158,198,158,206,159,210,159,210,162,211,163,211,167,212,168,213,170,213,175,214,177 214,182,213,183,213,184,212,184,212,185,209,185,208,186,205,186,204,187,183,187,181,186,178,184,176,183 e|********* m162,170 l165,170,167,169,169,169,172,168,176,167,180,167,184,165,189,164,193,163,196,161,200,161 e|********* m184,144 l197,144 e[/whitepad]
何作军 发表于 2009-11-27 22:27:52 | 显示全部楼层
程序不错,比较简洁。。。。
zhch1983 发表于 2009-12-15 10:54:28 | 显示全部楼层
也可以用汇编语言编的 和C一样 但要在电脑里安装在DOS下调试!好了以后还要用专门的烧入器烧入到51单片机内 51单片机开发实际上是需要很多外围电路的 什么晶振啊解码芯片等!没有专业的电子知识很难开发出实际的东西出来!程序只是其中的一步而已!51单片机有一个型号是80C51 好像只要10块钱就可以买一块!但是配套的其他电子元件加起来也要20 30块 所以实际上自己开发出来的并不便宜!劝那些非DIY就不要试图开发什么了 如果是个人爱好,可以试一试!
renmin 发表于 2010-1-2 13:06:35 | 显示全部楼层
废话,开发一套漂亮的广告灯控制程序加PCB,多的话,不到20块钱,
qqsw 发表于 2010-1-7 18:04:01 | 显示全部楼层
恩..严重同意楼上。...而且花样可以随便更改....
85569348 发表于 2010-1-12 13:01:26 | 显示全部楼层
( ⊙ o ⊙ )啊!速度法国人过放电高发
yjicss123 发表于 2010-1-24 15:32:40 | 显示全部楼层
程序很简练但这种控制器不实用
chuangxin 发表于 2010-1-26 22:57:02 | 显示全部楼层
楼主同时做注释更好啊!这样看来难明啊
tidi555 发表于 2010-3-24 09:06:44 | 显示全部楼层
{:1_137:}{:1_137:}{:1_137:}{:1_137:}{:1_137:}{:1_137:}
138138138 发表于 2010-6-2 14:04:02 | 显示全部楼层
我也学习学习学习学习
lgb728 发表于 2010-7-3 15:37:49 | 显示全部楼层
这个程序太简单,几本没有实用价值
飞月广告 发表于 2010-7-3 20:45:00 | 显示全部楼层
这个程序太简单,几本没有实用价值
GMT+8, 2026-11-19 10:56
