查看: 6549|回复: 22
走字灯箱全都花了
丹顶鹤 发表于 2009-2-18 16:22:41 | 显示全部楼层 |阅读模式
我做了第一个走字灯箱可是刚开始还好,只有几个地方有不该着的灯着了,我仔细检查发现有的灯珠用万用表量全通了!估计是在加工的时候被静电击穿了!我开是换,换了大概有100多个(我做的是16X96的)可是还完后更花了,我现在都不知道是什么原因,我在检查时发现几乎所有的灯都坏了!我现在不知道是什么原因,请大家帮忙找找原因!
xwt 发表于 2009-2-18 20:18:23 | 显示全部楼层
看看是不是什么地方绝缘没有搞好,引入了市电了
woshishui10 发表于 2009-2-20 10:24:23 | 显示全部楼层
老大详细说说,我以后也可以注意啊
笑问天 发表于 2009-2-20 18:26:36 | 显示全部楼层
[whitepad]***400;200;400,200;;** m123,94 l119,95,113,100,103,124,102,131,102,139,103,142,110,149,118,152,126,154,137,156,162,156,176,154,193,152,206,147,215,144,224,140,228,134,230,127,230,120,229,113 227,110,224,103,221,97,217,94,214,91,210,88,203,85,193,82,185,80,176,77,165,73,154,71,142,69,128,68,102,66,90,65,3,65 e[/whitepad]
 楼主| 丹顶鹤 发表于 2009-2-21 11:27:40 | 显示全部楼层
仔细检查过了!发现多数灯击穿了!更换后问题解决!但是不知道为什么会击穿,我估计是静电太大了!目前我没办法解决!
xwt 发表于 2009-2-21 18:40:30 | 显示全部楼层
呵呵,不是没办法解决,估计你什么地方引入了市电,只是你没有觉察出来
{:1_121:}
3302 发表于 2009-3-25 16:55:51 | 显示全部楼层
[whitepad]***400;200;400,200;;** m41,30 l41,50,39,62,36,73,32,83,27,94,22,104,18,110,14,115,11,119,10,119,10,118,9,117,9,111 e|********* m62,34 l99,34,101,35,104,36,106,37,109,38,111,38,115,40,115,41,117,43,117,55,115,58,113,60,112,62,110,65,108,67,104,70,98,74,91,81,89,82,85,85 85,86,84,86 e|********* m64,66 l64,65,72,65,78,62,81,61,83,60,84,60,85,59,86,59,87,58 e|********* m50,85 l50,86,60,86,63,85,65,84,75,84 e|********* m62,24 l62,28,63,31,63,34,64,38,64,47,65,54,67,57,67,60,68,65,68,70,70,84,70,92,72,95,72,101,73,105,73,109,74,114,74,117,75,120,75,128 76,131,77,133,77,138,78,139,78,140,120,140,127,138,133,136,137,135,139,134,141,134,142,133,143,133,144,132,145,132,147,130,147,129 e|********* m180,51 l195,51,203,49,209,48,216,47,221,47,225,45,226,45 e|********* m168,56 l170,56,171,57,171,63,179,79,180,87,183,95,183,103,184,112,184,126,181,131,180,135,179,137,179,140,177,142,176,141 e|********* m185,98 l191,98,196,96,199,96,204,94,214,94,216,93 e|********* m209,84 l209,125 e|********* m194,128 l228,128,231,129,235,129,236,130,245,130 e|********* m227,108 l230,108,230,110 e|********* m280,37 l284,37,286,38,287,39,288,41,291,44,291,45,293,45,295,46,296,47 e|********* m266,62 l276,61,289,59,301,58,310,58,327,56,346,54,363,53,369,52,379,50,380,50 e|********* m288,77 l290,77,293,79,296,83,297,85,299,87,301,91,303,93,305,96,313,104,319,106,333,106,341,103,347,102,353,98,356,95,356,94,355,93,355,91,354,91,354,88 348,82,347,82,345,81,310,81 e|********* m296,107 l296,123,297,127,297,144,299,152,299,155,300,159,300,166,299,166,297,164 e|********* m300,122 l359,122,369,120,376,120,381,118,384,118,386,120,386,127,388,133,388,155,385,159,384,164,382,168,381,171,378,175,372,180,369,182,368,183,365,184,361,186,352,186 351,185,350,185,349,184,347,183,346,183,345,182,344,180,342,178 e|********* m343,139 l342,138,338,138,334,142,332,142,332,143,329,149,329,150,328,151,328,157,330,159,330,160,331,161,332,163,334,163,334,162,335,162,338,160,340,159,342,159,348,155 350,154,351,154,354,151,354,143,334,143 e[/whitepad]
sss999 发表于 2009-3-25 17:41:25 | 显示全部楼层
应该不是坏了,我也遇到过 我这个跟你那个一摸一样的效果 不过 我把背板去掉 敞开着就没事!
232724661 发表于 2009-3-25 20:47:04 | 显示全部楼层
新手问题多多,我好害怕啊,不敢入手了都。
hongzikai 发表于 2009-3-28 10:39:45 | 显示全部楼层
学习中,多检查,多总结,不要急着通电.
jinqiao 发表于 2009-4-4 20:42:59 | 显示全部楼层
是的,没错,多检查,不要急着通电.
xzd666 发表于 2009-4-4 22:04:16 | 显示全部楼层
多看论坛,做的时候仔细点,先做小点的,不然亏大发了
monkey2008 发表于 2009-4-25 00:11:18 | 显示全部楼层
我做的每个都会出现烧毁的情况,郁闷
吴学民 发表于 2009-4-25 12:37:08 | 显示全部楼层
是不是电烙铁绝缘不好了?
jsxzgyj 发表于 2009-5-8 23:00:55 | 显示全部楼层
测量输出电压了没有,是否正常 1# 丹顶鹤
zkzazja 发表于 2009-5-10 22:19:53 | 显示全部楼层
学习中,多检查,多总结,不要急着通电
gogo539232 发表于 2009-5-11 11:13:20 | 显示全部楼层
学习啦,新手入门!好怕怕哦
三皮匠 发表于 2009-9-3 23:00:00 | 显示全部楼层
好可怕啊!!!!!!!
知焉斋 发表于 2009-9-5 17:09:05 | 显示全部楼层
前车之师,。。。。。。。。。。。。。
huxingming 发表于 2009-9-5 20:42:54 | 显示全部楼层
仔细仔细再仔细................
GMT+8, 2026-11-18 05:06
