查看: 3617|回复: 11
看看我给客户做的字
123lym 发表于 2009-5-28 20:05:09 | 显示全部楼层 |阅读模式
zldhkmm 发表于 2009-5-28 21:02:45 | 显示全部楼层
很不错                                                      ,
szhcgg 发表于 2009-5-29 13:44:48 | 显示全部楼层
立体边是什么材料?铁皮烤漆??
 楼主| 123lym 发表于 2009-5-29 13:53:40 | 显示全部楼层
是专用3cm发光字边条.
 楼主| 123lym 发表于 2009-5-29 13:55:41 | 显示全部楼层
面板是3mm亚克力,底板是5cmpvc板.
wzy0000 发表于 2009-6-1 11:20:36 | 显示全部楼层
[whitepad]***400;200;400,200;;** m77,42 l77,46,72,52,63,58,54,62,49,66,48,68,48,69,49,70,57,71,66,72,69,73,73,73,74,74,74,79,72,81,65,85,58,87,51,92,47,94,46,95 45,97,45,99,58,99,61,101,62,103,64,105,64,123,70,124,79,122,85,116,87,111,85,102,82,96 e|********* m96,53 l96,51,99,51,102,49,107,47,116,44,124,44,125,42,125,43,120,68,117,77,110,81,108,81,106,78,105,75,103,73,103,72,104,71,109,69,108,69,106,71 102,74,99,78,99,79,101,77,105,74,110,64,110,59,107,52,104,48,104,47,102,48,100,53,97,61,94,72,91,87,89,99,89,115,90,128,92,135,97,142 99,142,100,140,102,130,105,114,106,99,108,91,109,85,109,83,107,84,103,88,102,93,100,98,100,105,104,109,116,116,125,119,127,119,125,117,122,115 e|********* m149,75 l150,76,150,116,151,127,152,131,152,130,154,119,155,105,158,93,161,84,164,79,165,76,166,74,166,66,148,101,141,114,137,120,136,122,137,115,141,106,149,97 158,91,167,88,183,83,191,83,191,87,186,94,184,98,182,104,182,108,184,112,188,117,194,122,195,123,196,123,196,124,192,124,191,122,187,120,181,115,179,109 178,107,179,105,184,102,193,97,198,93,199,92 e|********* m243,38 l244,38,251,31,255,29,256,27,256,29,251,38,230,62,236,62,255,60,260,60,261,58,259,58,257,59,247,68,229,80,224,83,217,84,214,86,215,86,237,80 262,78,283,73,283,71,281,71,270,62,262,58,257,55,253,53,250,46,248,42,248,38,249,38,249,44,247,51,244,59,240,77,235,89,223,118,222,123,220,126 220,127,221,125,230,114,234,109,242,103,245,100,245,114,243,130,241,137,241,138,243,129,250,110,260,88,268,88,269,89,270,92,271,98,274,103,275,108,275,141 276,144,276,152,277,153,275,153,273,149,267,136,263,127,262,123,258,115,256,113,254,112,254,109,260,109,261,110,261,114,257,118,255,119,251,120,253,121,255,121 257,122,257,124,255,125,252,127,248,131,248,136,265,136,262,134,256,132 e[/whitepad]
 楼主| 123lym 发表于 2009-6-1 21:57:38 | 显示全部楼层
我装了20多块LED招牌都是用老大的LED灯和控制器还没有返修过.主要是要把防水做好、电阻要接正确,不要电阻太热等.
zldhkmm 发表于 2009-6-3 10:22:11 | 显示全部楼层
嗯,学习了                                      .
迷途小熊 发表于 2009-6-3 12:11:52 | 显示全部楼层
做的很漂亮啊,很用心{:1_83:}
仙河光电 发表于 2009-6-4 07:22:24 | 显示全部楼层
刚做了个灯箱,请教各位高人,电阻发热量有多大?会不会把与它接触的连线烤化掉
兰兰的海 发表于 2009-6-4 13:03:24 | 显示全部楼层
做的很漂亮.成本是 多少呀??再接再厉!!
 楼主| 123lym 发表于 2009-6-4 13:13:25 | 显示全部楼层
成本100元左右!!!!!!!!!!!!
GMT+8, 2026-11-22 05:10
