查看: 1752|回复: 0
LM5032高电压双路交错电流模式控制器
拍明芯城 发表于 2018-8-22 17:12:08 | 显示全部楼层 |阅读模式
  The LM5032 dual current mode PWM controller contains all the features needed to control either two independent forward dc/dc converters or a single high current converter comprised of two interleaved power stages. The two controller channels operate 180° out of phase thereby reducing input ripple current. The LM5032 includes a startup regulator that operates over a wide input range up to 100 V and compound (bipolar + CMOS) gate drivers that provide a robust 2.5-A peak sink current. The adjustable maximum PWM duty cycle reduce stress on the primary side MOSFET switches. Additional features include programmable line undervoltage lockout, cycle-by-cycle current limit, hiccup mode fault operation with adjustable response time, PWM slope compensation, soft-start, and a 2-MHz capable oscillator with synchronization capability.
  For all available packages, see the orderable addendum at the end of the datasheet.
  Two Independent PWM Current Mode Controllers
  Integrated High-Voltage Startup Regulator
  Compound 2.5-A Main Output Gate Drivers
  Single Resistor Oscillator Setting to 2 MHz
  Synchronizable Oscillator
  Programmable Maximum Duty Cycle
  Maximum Duty Cycle Fold-Back at High-Line Voltage
  Adjustable Timer for Hiccup Mode Current Limiting
  Integrated Slope Compensation
  Adjustable Line Undervoltage Lockout
  Independently Adjustable Soft-Start (Each Regulator)
  Direct Interface with Opto-Coupler Transistor
  Thermal Shutdown
  TSSOP 16-Pin Package
  相关终端应用 (10)
  Drone Accessories
  交流逆变器和 VF 驱动器
  制造机器人
  可再生能源存储 - 锂聚合物电池管理器
  工业 AC-DC
  无刷直流电机驱动器
  物料搬运(叉车、仓库机器人等)
  电动交通工具(电动自行车、电动滑板车和电动汽车)
  电器电池充电器
