查看: 2176|回复: 0
UCC25600型号8 引脚高性能谐振模式 LLC 控制器
拍明芯城 发表于 2018-8-22 17:11:06 | 显示全部楼层 |阅读模式
  The UCC25600 high performance, resonant mode controller is designed for dc-to-dc applications using resonant topologies, especially the LLC half-bridge resonant converter. This highly integrated controller implements frequency modulation control and complete system functions in only an 8-pin package. Switching to the UCC25600 will greatly simplify the system design and layout, and improve time to market, all at a price point lower than competitive 16-pin device offerings.
  The internal oscillator supports the switching frequencies from 40 kHz to 350 kHz. This high-accuracy oscillator realizes the minimum switching frequency limiting with 4% tolerance, allowing the designer to avoid over-design of the power stage and, thus, further reducing overall system cost. The programmable dead time enables zero-voltage switching with minimum magnetizing current. This maximizes system efficiency across a variety of applications. The programmable soft-start timer maximizes design flexibility demanded by the varied requirements of end equipment using a half-bridge topology. By incorporating a 0.4-A source and 0.8-A sink driving capability, a low cost, reliable gate driver transformer is a real option.
  The UCC25600 delivers complete system protection functions including overcurrent, UVLO, bias supply OVP, and overtemperature protection.
  Variable Switching Frequency Control
  Programmable Minimum Switching Frequency
  With 4% Accuracy (3% Accuracy at Temperature
  Range: –20°C to 105°C)
  Programmable Maximum Switching Frequency
  Programmable Dead Time for Best Efficiency
  Programmable Soft-Start Time
  Easy ON and OFF Control
  Overcurrent Protection
  Overtemperature Protection
  Bias Voltage UVLO and Overvoltage Protection
  Integrated Gate Driver With 0.4-A Source and 0.8-
  A Sink Capability
  Operating Temperature Range: –40°C to 125°C
  SOIC 8-Pin Package
