查看: 3440|回复: 0
仰邦科技推出3G模块适合无线应用流量发送3G模块使用说明2014.5.1版本
笑问天 发表于 2014-5-3 10:35:55 | 显示全部楼层 |阅读模式
BX-3G 用户手册
BX-3G 用户手册
上海仰邦软件科技有限公司
- 1-
BX-3G 用户手册
Copyright
All rights reserved. No part of this publication may be reproduced in any form by print, photo print,
microfilm or any other means without written permission by ONBON.
© 2010-2011 Onbon
上海仰邦软件科技有限公司
- 2-
BX-3G 用户手册
目录
第 1 章. 产品概述........................................................................................................................... 3
1.1 产品介绍........................................................................................................................... 3
1.2 产品特点........................................................................................................................... 3
1.3 参数指标........................................................................................................................... 3
1.4 产品外观........................................................................................................................... 4
1.5 接口说明........................................................................................................................... 4
第 2 章.WEB 设置页面..................................................................................................................... 5
2.1 准备工作........................................................................................................................... 5
2.2 设置页面介绍.................................................................................................................... 6
2.2.1 页面主菜单.............................................................................................................. 6
2.2.2 常用设置页面.......................................................................................................... 6
2.2.3 系统管理页面.......................................................................................................... 8
2.3 高级设置页面.................................................................................................................. 10
2.4 注意事项......................................................................................................................... 11
第 3 章. 短信命令配置.................................................................................................................. 12
3.1 基本格式......................................................................................................................... 12
3.2 命令关键字列表............................................................................................................... 12
3.3 命令实例......................................................................................................................... 13
3.4 短信回复......................................................................................................................... 13
3.5 注意事项......................................................................................................................... 14
第 4 章. 图文编辑软件配置实例................................................................................................... 15
第 5 章. 简单故障排除.................................................................................................................. 17
上海仰邦软件科技有限公司
- 3-
BX-3G 用户手册
第 1 章.  产品概述
1.1  产品介绍
BX-3G 系列工业无线路由器采用高性能 32 位处理器与工业级 3G 无线模块作为硬件主
框架,并使用高度模块化、高度自动化的嵌入式系统作为软件支撑平台,集成了全系列从
逻辑链路层到应用层通信协议,借助公用 3G 网络(WCDMA 或 EVDO)为用户提供安全、高
速、稳定可靠的无线网络接入。
1.2  产品特点
 高速接入
BX-3GW 采用 HSDPA/HSUPA 接入,提供 7.2Mbps 下行速度和 5.76Mbps 的上行速度
BX-3GE 采用 EVDO RevA 接入,提供 3.1Mbps 下行速度和 1.8Mbps 的上行速度
 工业化设计
采用高性能工业级无线模块
采用金属外壳,防护等级为 IP30,特别适合于工控现场的应用
以太网口支持 1.5KV 隔离变压保护
宽温支持:-30℃~70℃
 高可靠性
实时检测无线链路状态,掉线自动重拔,保持无线链路长时间连接
内嵌硬件看门狗,设备运行故障自修复,保障设备维持高可用性
抗干扰、防静电设计,适合电磁环境较恶劣的应用需求
 简单易用,便于操作维护
丰富的网络管理方式,支持短信、WEB、网管平台多种配置方法,方便易用,部署快速
WEB 界面各个功能根据 IT 人员习惯进行归类,清晰明了,提升用户配置效率
支持本地或远程读取日志,通过日志帮助工程师迅速定位问题,提高工作效率
1.3  参数指标
 供电:+5V DC(直流)输入
 平均工作电流:650mA@+5V DC
 最大瞬时电流:2.0A@+5V DC
 工作频段:BX-3GW:UMTS/HSDPA/HSUPA 850/1900/2100MHz
GSM 850/900/1800/1900MHz
BX-3GE:CDMA2000 1x/EVDO Rev.A 800/1900MHz
 工作温度:-30℃—70℃
 外观尺寸:124mm X 100mm (不包括天线)
上海仰邦软件科技有限公司
- 4-
BX-3G 用户手册
1.4  产品外观
1.5  接口说明
前面板从右到左依次为:
 直流电源接口,用于+5V 电源输入。
 内陷 RST 按钮,用于回复出厂设置。系统正常运行时,按住该按钮 5 秒钟,设备
将恢复出厂设置并重新启动。
 红色 PWR 指示灯,常亮表明系统已上电。
 黄色 SYS 指示灯,心跳式闪烁表明系统正常运行(启动过程常亮)。
 绿色 GTM 指示灯(启动过程常亮):
指示灯状态 含义
快速闪烁 正在拨号过程中
慢速闪烁 拨号完成,已连接 3G 网络
心跳式闪烁 已连接上中转服务器
常亮(非启动过程)或熄灭 拨号故障
 10/100M 自适应以太网 RJ45 接口,用于连接各类型控制卡。该 RJ45 接口带有连接
指示灯位于接口的左下方,熄灭表明以太网未连接,常亮表明已正确连接,偶尔
闪烁表明有数据正在传输。
后面板有标准 50 欧姆 SMA 阴头天线接口和抽屉式 SIM 卡接口,分别用于连接 3G 无线
网络所需的全波段天线和放置 1.8/3V UIM/SIM 卡。
上海仰邦软件科技有限公司
- 5-
BX-3G 用户手册
第 2 章.  WEB设置页面
2.1  准备工作
 将 BX-5G 路由器接通 5V 电源
 打开计算机网络连接属性,双击“Internet 协议版本 4(TCP/IPv4)”,设置 IP
地址为“自动获得 IP 地址”:
图 2-1  网络连接属性
图 2-2  设置“自动获得 IP 地址”
上海仰邦软件科技有限公司
- 6-
BX-3G 用户手册
 使用交叉网线连接计算机与 BX-3G 路由器,计算机将自动获取正确的 IP 地址
 打开浏览器,在地址栏输入“http://192.168.1.1”,回车,在首页显示后 2—3
秒将自动进入登录页面:
图 2-3  登录页面
 在登录页面中输入用户名“admin”,密码“123456”(出厂时的默认密码),回
车或点击“登录”按钮进入常用设置页面,即可进行路由器配置
2.2  设置页面介绍
2.2.1  页面主菜单
菜单栏分为“路由器状态”、“常用设置”、“系统管理”和“退出”四个功能菜单。
“路由器状态”菜单用于显示路由器的主要状态,没有设置功能;“常用设置”包含了常
用的的设置项,如局域网设置、3G 拨号设置、中转服务器设置等;在“系统管理”中,可
以设置路由器的配置页面语言,更改管理员密码,备份和恢复路由器配置,升级路由器固
件,以及重新启动路由器,“退出”菜单用于登出配置页面。
图 2-4  设置页面主菜单
2.2.2  常用设置页面
该页面包含了常用的的设置项,如中转服务器设置、3G 拨号设置、局域网设置等。修
改配置需重启后,新的配置才生效。
“网络连接”设置栏用于设置 3G 拨号参数,主要有:运营商特定的拨号号码、用户
名、密码等。除了特殊应用场合外,此页面参数请勿随意修改。
“本地网络”与“DHCP 服务”设置栏用于设置路由器局域网 IP、子网掩码、DHCP 服
务的地址池范围及租约时间等。没有特殊需求,无需修改。可以在“静态地址分配”栏为
某些特定的 MAC 地址指定 IP。路由器的默认 IP 为“192.168.1.1”。
“BX 中转服务”设置栏用于设置仰邦公司中转网管平台连接参数。在不使用仰邦公司
提供的(或自建的)中转网管服务平台时,可以禁用此功能。使能中转服务后,可设置包
括服务器主机域名(或 IP)、端口、重新连接间隔时间、重新连接尝试次数等参数。除了
域名/IP 外,其他参数不填写表明使用默认设置。
在网络“状态”栏可以查看当前局域网与 3G 广域网的 IP、MAC、流量等信息。
上海仰邦软件科技有限公司
- 7-
BX-3G 用户手册
在 DHCP“活动客户端”栏可以查看当前已分配的 IP 与主机 MAC 等信息。
上海仰邦软件科技有限公司
- 8-
BX-3G 用户手册
图 2-5  常用设置页面
2.2.3  系统管理页面
该页面下设“系统设置”、“更改密码”、“备份/升级”和“重启”四个子菜单。
图 2-6  系统管理子菜单
 “系统设置”页面用于设置路由器的主机名、时区、页面语言
其中的“同步浏览器时间”按钮用于使路由器的系统时间与浏览器的系统时间同步。
上海仰邦软件科技有限公司
- 9-
BX-3G 用户手册
图 2-7 系统设置页面
 “更改密码”页面用于更改管理员密码
图 2-8  更改密码页面
 “备份/升级”页面用于备份和恢复路由器配置,升级路由器固件
上海仰邦软件科技有限公司
- 10-
BX-3G 用户手册
图 2-9  备份/升级页面
“执行复位”按钮用于将路由器的配置恢复到出厂时的默认状态。点击后,路由器将
自动重启,并恢复出厂配置。
点击“生成备份”按钮,将下载路由器当前配置的压缩包,文件名为“backupOnbonBX-YYYY-MM-DD.tar.gz”,用于日后恢复配置。
点击“恢复配置”输入框或其后的“浏览…”按钮,在跳出的文件选择框中选择需要
恢复的配置压缩包后,点击“上传备份…”按钮,路由器将自动重启,并恢复压缩包中的
配置。
“刷新固件”栏用于升级路由器固件,“保留配置”选项用于选择刷新固件时是否保
留当前配置。点击“映像文件”输入框或其后的“浏览…”按钮,在跳出的文件选择框中
选择固件文件后,点击“刷新固件…”按钮,路由器将上传该固件文件,并作简单格式判
断。如上传的固件文件格式正确,将跳出新的固件验证页面。由于路由器不能保证固件文
件的完整性,刷新前请核对固件的 MD5 校验核,如有错误,请点击“取消”按钮中止
刷新。确认固件无误后点击“执行”按钮,路由器开始刷新固件,持续时间 2-3 分钟,期
间请勿断电。
图 2-9  上传了错误的固件文件
图 2-9  固件验证页面
上海仰邦软件科技有限公司
- 11-
BX-3G 用户手册
 在“重启”页面中点击“执行重启”链接,将重新启动路由器
图 2-10  重启页面
2.3  高级设置页面
在浏览器地址栏输入“http://192.168.1.1/admin”,回车,在首页显示后 2—3 秒
自动进入登录页面,输入管理员秘密并点击“登录”按钮,进入高级设置页面:
图 2-11  高级设置首页面
高级设置页面拥有路由器设置的高级功能,设有状态、系统、服务和网络四个主菜单。
高级设置页面下的设置需要一定的网络知识,不建议一般操作人员随意修改。
(a)状态菜单
(b)系统菜单
(c)服务菜单
(d)网络菜单
图 2-12  高级设置菜单
上海仰邦软件科技有限公司
- 12-
BX-3G 用户手册
2.4  注意事项
 配置修改后,需手动重启路由器使之生效
 更改页面语言后,点击“退出”菜单重新登陆生效
 更改密码提交后,将要求使用新密码重新登陆
 执行恢复配置后,路由器将自动重新启动
 执行刷新固件前,请先核对固件校验值
 3G 拨号参数请勿随意修改
 刷新固件期间切勿断电
上海仰邦软件科技有限公司
- 13-
BX-3G 用户手册
第 3 章.  短信命令配置
BX-3G 系列路由器可通过短信命令的方式更改部分配置参数, 短信命令遵循以下格式:
(PASS#CMD*PARAM)。
3.1  基本格式
短信命令的基本格式为:(PASS#CMD*PARAM),其中:
“PASS”为验证短信有效性的密码,默认为“A55A”。
“CMD”为命令关键字,用于指示配置的项目。
“PARAM”为配置项目的参数字段,不同的配置项目有不同的参数个数,可能没有,
也可能有多个,多个参数情况下参数间以‘*’隔开。
一条短信可以发送多个命令,称为组合命令,命令间以“#”隔开。组合命令允许最
多八条命令组合在一起,超过八条的组合命令将被截尾处理,即只执行前八条命令,超过
部分被舍弃。如参数本身带有“*”“#”字符(包括后面的转义字符“/”本身),必须
在之前添加转义字符“/”。
3.2  命令关键字列表
关键字
参数
个数
作用介绍 完整
字段
简短
字段
APN 3 1 配置 3G 无线网络 APN
ECH c 1 打开或关闭短信回复
LIP i 2 设置路由器局域网 IP 地址与掩码
PWD p 2
修改短信命令验证密码
设置后立刻生效
RST r 0
重启路由器
注意:重启命令须单独使用,或者置于组合命令最后
SIP 1 1/2 配置中转服务器 IP 及端口,该参数设置后,下次连接服务器时生效
SDN 2 1/2
配置中转服务器域名及端口,该参数设置后,下次连接服务器时生效
该命令与 SIP 命令作用完全相同,域名与 IP 可以互换
TPN t 1
添加允许发送短信命令的手机号码
注意:组合命令中避免使用该命令
带空参数使用该命令,将清除已添加的所有号码
WDC w 3 设置 3G 无线网络拨号参数
STA s 0
查询设备运行状态
注意:该命令只能单独使用,并且不受 ECH 命令影响
STE e 0
查询设备运行扩展状态
上海仰邦软件科技有限公司
- 14-
BX-3G 用户手册
3.3  命令实例
命令 实例 描述
APN
(A55A#apn*3gnet)
设置 3G 无线网络的 APN 为 3gnet
(A55A#3*3gnet)
ECH
(A55A#ech*1) 打开短信回复
(A55A#e*0) 关闭短信回复
LIP
(A55A#lip*192.168.1.1*255.255.255.0) 设置路由器局域网 IP 为 192.168.1.1
子网掩码为 255.255.255.0 (A55A#i*192.168.1.1*255.255.255.0)
PWD
(A55A#pwd*CFPW*CFPW) 设置短信命令验证密码为 CFPW
两个参数必须相同才能成功修改密码 (A55A#p*CFPW*CFPW)
RST (A55A#rst)或(A55A#r) -SIP
SDN
(A55A#sip*112.65.247.181*5010) 设置中转服务器 IP 地址为 112.65.247.181
端口为 5010 (A55A#sdn*112.65.247.181*5010)
(A55A#1*www.onbonbx.com) 设置中转服务器域名为 .onbonbx.com
端口采用默认 (A55A#2*www.onbonbx.com*)
TPN
(A55A#tpn*138000011111) 添加 138000011111 为配置手机号
(A55A#t*) 清除已设置的所有配置手机号
WDC
(A55A#wdc**card*card)
设置 3G 无线 APN 为空
用户名为 card,密码为 card
(A55A#w*3gnet*uninet*)
设置 3G 无线 APN 为 3gnet
用户名为 uninet,密码为空
(A55A#wdc*cmnet**)
设置 3G 无线 APN 为 cmnet
用户名为空,密码为空
STA (A55A#sta)或(A55A#s) -STE (A55A#ste)或(A55A#e) -3.4  短信回复
当短信回复功能打开时,路由器才会在收到短信命令后回复操作结果短信。状态查询
命令 STA 与 STE 不论短信回复功能是否打开都回复。
STA 与 STE 查询命令正确接收后,路由器将返回格式为(A#B#C#D#E#...)的结果短信,
各字段的含义如下表:
字段 字段解析及含义
STA
主状态
举例:(bx000001#1# 112.65.247.181:5001#cmnet#1#V11090080)
A bx000001,设备 ID
B V11090080,固件版本代号
C 1,与中转服务器的连接状态已连接;(0 为未连接)
D
112.65.247.181:5001,
中转服务器的 IP(或域名)与端口,没有设置时为空
E cmnet,3G 无线网络的 APN,没有设置时为空
F 1,3G 无线网络已连接;(0 为未连接)
STE
扩展状态
举例:(10.35.77.84#192.168.1.1###4)
A 10.35.77.84,广域网 IP;(并不一定是公网 IP,由运营商而定)
B 192.168.1.1,路由器局域网 IP
C 空,3G 无线网络拨号用户名为空
D 空,3G 无线网络拨号密码为空
E
4,3G 无线网络信号强度较强
(0:无信号,1:很弱,2:较弱,3:一般,4:较强,5:很强)
上海仰邦软件科技有限公司
- 15-
BX-3G 用户手册
3.5  注意事项
 3G 网络运营商对于数据业务类型的帐号在短信服务上一般有限制,大部分数据套
餐是不包含短信服务的,需要另行开通。没有开通短信服务时,使用短信查询命
令和短信回复功能,可能会自动开通并产生资费,导致欠费无法上网。
 短信内容必须是半角的英文和数字,不能是全角的字符,即短信命令的所有字符
内容均在数字或者字母状态下输入,不能在中文输入法下输入。
 两个括号“(”“)”是配置内容的一部分,配置的时候也要输入。
 短信命令的命令关键字不分大小写。
 短信命令不支持长短信格式。
 短信命令的最大字符数为 160。
 短信命令的参数字段中的“*”“#”“/”字符前必须添加转义字符“/”。
 组合命令是顺序执行的。
 超过八条的组合命令将被截尾处理 。
 设置密码为固定 4 字符,限定为数字 0—9 及 26 个英文字母(区分大小写)。
 在没有添加任何号码前,允许任何号码发送短信命令;一旦添加后,只允许被添
加的号码发送短信命令。
 最多支持 3 部命令手机号,超过 3 部,继续添加,最先添加的号码将被取代。
上海仰邦软件科技有限公司
- 16-
BX-3G 用户手册
第 4 章.  图文编辑软件配置实例
 本实例需要通过端口映射作为虚拟服务器的计算机,具体操作方法参照“GPRS 软
件设置说明”
 将所需配置的控制卡与 PC 计算机单独用网线连接,并打开本公司“LedshowTW
2014 图文编辑软件”
 点击菜单“设置”->“设置屏参”,在跳出的密码对话框中输入密码“888”
 在“控制组件”中选择相应的控制卡型号;在“通讯模式”中选择“网络通讯”;
在“网络连接模式”中选择“服务器模式”
上海仰邦软件科技有限公司
- 17-
BX-3G 用户手册
 点击“控制器 IP 配置”按钮,在“控制器 IP 配置”窗口中, 设置“IP 地址”为
192.168.1.100,“子网掩码”为 255.255.255.0,“网关”为 192.168.1.1;设
置“服务器 IP 地址”为公网固定 IP,“服务器端口”根据端口映射设置;最后点
击“设置”按钮,完成控制卡 IP 设置
 点击“网络服务器端配置”,在“网络服务器端配置”窗口中点击“获取本机
IP”,“端口”同端口映射一致,最后点击“启动服务器”按钮完成
 将控制卡与 PC 断开,接到 BX-3G 路由器网口上,等待控制卡上线,即可加载节目
未上线: 上线后:
上海仰邦软件科技有限公司
- 18-
BX-3G 用户手册
第 5 章.  简单故障排除
在 BX-3G 路由器的应用中,大部分故障的外在现象都表现为所连接的控制卡无法连接
到上位机软件,但是引发的内在原因却有多种可能。通过指示灯可以初步判断某些原因:
 PWR 指示灯处于熄灭状态。原因是未正确上电,请检查输入电源的电压与极性。
 RJ45 接口指示灯熄灭。表明以太网没有正确连接,请检查网线是否连接或更换网
线。
 SYS 指示灯处于心跳式闪烁状态,GTM 指示灯长时间处于常亮状态。可能的原因是
未正确插入 UIM/SIM 卡,UIM/SIM 卡不允许在上电后再插入。处理方法,确保先插
入 UIM/SIM 的前提下重新上电。
 SYS 指示灯处于心跳式闪烁状态,GTM 指示灯长时间处于快速闪烁状态。可能的主
要原因有几种:未连接天线、所在区域的信号太弱或者 SIM/UIM 欠费。请先检查
天线连接;天线正确连接的前提下变更天线的位置,看 GTM 指示灯是否能变为慢
速闪烁状态;最后,咨询运营商 UIM/SIM 卡资费情况。
 SYS 指示灯处于心跳式闪烁状态,GTM 指示灯长时间处于熄灭状态。多次重新启动
后,指示灯状态依旧,这种情况需返厂维修。
 SYS 指示灯长时间处于常亮或熄灭状态。多次重新启动后,指示灯状态依旧,这种
情况需返厂维修。
 SYS 指示灯与 GTM 指示灯交替闪烁,这种情况需返厂维修。
上海仰邦软件科技有限公司
- 19-
GMT+8, 2026-11-24 20:43
