查看: 3009|回复: 7
有不明白的了
齐齐哈尔新手 发表于 2009-2-9 23:14:28 | 显示全部楼层 |阅读模式
请问斑竹假如我想做一个特定尺寸的led走字屏,led排列后和尺寸不相应怎么办?把led点距加宽清晰度肯定降低,点距过近铝塑板就会断裂,请问斑竹怎么解决?
  还有,led条屏能不能做10或12字的,或者11字的?
xwt 发表于 2009-2-10 08:22:50 | 显示全部楼层
空出一块地方,用其他东西,比如跑马灯装饰,东西是死滴,人是活滴
七彩光电 发表于 2009-2-10 12:39:27 | 显示全部楼层
可以做 11字的。用手工做法,不要用成品的单元板。换用合适的边框材料是可以调整好尺寸的。你的尺寸不会那么精确吧?{:1_144:}
 楼主| 齐齐哈尔新手 发表于 2009-2-10 13:01:46 | 显示全部楼层
谢谢大家!我还想问能不能一块驱动板只驱动一个字啊?比如遇到11字的。
xwt 发表于 2009-2-10 15:04:01 | 显示全部楼层
[whitepad]***400;200;400,200;;** m38,69 l38,67,46,71,70,95,77,103,81,110,85,118,86,119,87,121,88,121,89,123,90,121,92,119,94,113,99,106,103,99,110,90,116,82,119,80,123,74,124,72 128,68,129,66,133,65,136,62,143,60,157,54,165,51,172,49,173,48,173,46,174,46,174,45,176,43,176,42,177,41,177,40,178,40,178,39,179,38,181,38 182,37,183,35,184,35,185,34,186,34,189,31,190,31,192,29,196,27,197,26,201,24,202,24,204,23,206,21,208,21,211,18,213,18,215,16,216,16,216,15 218,14,219,14,220,13 e|*******#60f;* m274,20 l276,20,276,24,277,25,277,29,275,29 e|********* m253,30 l253,32,254,33 e|********* m256,30 l257,30,261,28,268,28,278,26,289,24,298,23,321,23,322,22,322,35,321,36,321,37,314,37 e|********* m271,42 l273,41,279,39,289,38,298,37,306,36,316,35,309,35 e|********* m302,31 l301,32,298,38,295,42,294,44,293,44,293,46,294,46,298,48,301,50,308,51,314,55,315,56,317,56,317,57,315,57,314,56,313,56,311,54 e|********* m278,46 l277,46,279,45,288,42,294,41,301,40,304,40,303,41,301,41,299,42,298,43,296,43,293,46,290,47,287,49,282,50,279,52,277,53,275,55,274,55 e|********* m305,49 l304,50,304,54,305,55,307,56,331,56,338,53,341,53,342,52,342,49,338,45,333,45 e|********* m263,69 l264,69,264,73,263,74,262,76,260,78,257,80,253,81,249,83,243,83 e|********* m290,70 l291,70,291,71,292,72,292,73,293,75,295,76,300,81,295,81 e|********* m251,89 l291,89,290,90 e|********* m237,105 l239,105,241,106,247,108,257,109,268,111,284,113,291,114,294,114,293,113,291,113,290,112,288,111 e|********* m279,106 l279,108,278,109,278,112,275,118,275,119,274,120,273,120,272,121,264,121 e|********* m230,120 l231,121,237,122,248,124,265,126,283,130,301,131,314,132,323,134,325,134 e|********* m166,143 l167,142,185,142,196,140,211,140,216,141,215,141 e|********* m209,141 l209,143,210,145,210,151,209,154,209,157,208,159,208,165,207,167,207,171,208,172,208,175,207,176,206,178,205,179,205,185,201,185,200,186,196,186,196,187,192,187 189,184,186,182,181,179,174,173,170,171 e|********* m175,157 l176,157,176,158,177,160,177,163 e|********* m181,152 l184,152,185,153,188,153,189,154,190,154,190,158,189,159,189,161,188,161,186,162,179,162,177,161,175,161 e|********* m174,160 l179,160,181,162,188,162,191,163,194,165,196,165 e|********* m226,148 l228,148,228,197,232,197,232,195,236,193,238,191,239,189,240,188,241,186,242,185,243,185,243,183,244,182,244,180 e|********* m243,162 l243,163,245,164,245,166,246,168,247,169,247,172,248,172,252,170 e|********* m300,151 l300,155,299,158,298,165,292,179,287,187,283,193,277,197,275,199,267,199,269,197 e|********* m288,180 l288,179,289,179,290,180,293,181,296,184,310,190,316,193,318,195,320,195,321,196,322,196,323,197,330,197,334,195 e[/whitepad]
卓越 发表于 2009-2-14 19:02:48 | 显示全部楼层
可以做 11字的。用手工做法——本文来自〖www.521LED.com〗原帖地址:http://www.521led.com/viewthread.php?tid=96&fromuid=244
七彩光电 发表于 2009-2-14 19:49:17 | 显示全部楼层
{:1_118:}
jrtx1180 发表于 2009-2-21 20:50:44 | 显示全部楼层
学习中!!!!!!!!!!!!
GMT+8, 2024-5-9 15:45
