查看: 16332|回复: 68
双色灯,制作方法,加电阻的方法
笑问天 发表于 2009-10-15 20:27:47 | 显示全部楼层 |阅读模式
红蓝和红绿双色很好看,显示好过已经经过验证,
[flash]
[/flash]
双色灯,有两点需要注意,,第一,他仍然是分正负的,虽然它接线的时候不分正负,但是他在串联的时候一定要分清楚正负。,看灯珠,里面大的那部分是负极。
第二,他串联电阻计算方法是和红色的灯是一样的,但每串最多不能超过80个,最佳使用范围是50-75个一串
25-35' F2 h$ c( f6 N* l
9k
2 y
36-45
8k* [2 d2 g4 ^; i. C' R
% d5 n" ]" W& B
 d! H
46-55
7k
56-65$ Z! G# j6 s1 h
6k( e; Q: D8 H6 Y) Z
& p- ^
66-75, u+ w6 }( R" n7 t
5k
banbeicha 发表于 2009-10-15 21:54:01 | 显示全部楼层
沙发  漂亮.....................................
qqsw 发表于 2009-10-16 03:05:03 | 显示全部楼层
好漂亮......价格呢..老大........
x710918 发表于 2009-10-16 12:19:42 | 显示全部楼层
hao~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
热风 发表于 2009-10-16 17:15:45 | 显示全部楼层
[whitepad]***400;200;400,200;;** m84,25 l81,28,77,31,75,33,71,36,65,40,63,42,61,43,57,48,52,53,50,54,46,58,43,60,41,62,46,61,53,59,60,58,68,57,75,55,81,54,84,54 84,55,82,58,80,59,77,64,72,68,67,71,63,73,58,75,56,77,53,77,52,78,44,80,32,84,30,85,30,86,29,86,30,87,35,88,46,88,52,89 56,90,59,91,60,91,60,92,64,96,67,102,69,109,71,115,72,121,74,131,74,140,73,142,71,143,71,144,70,145 e|********* m97,52 l97,46,102,41,104,41,108,40,114,40,117,41,118,42,120,42,121,43,123,44,124,44,125,46,126,49,127,50,127,56,126,60,124,64,122,66,120,69,119,70 115,73,112,75,103,78,94,78,93,79,92,78 e|********* m91,69 l91,68,93,67,94,65,97,64,99,63,100,62,101,62,103,61,105,59,107,59,108,58,109,58 e|********* m95,78 l96,77,100,74,103,74,108,72,110,70,112,70,112,69,113,69 e|********* m86,59 l86,60,87,62,88,66,88,77,87,78,85,83,83,86,82,89,81,91,80,92,80,93,79,96,78,98,78,99,77,100,77,105,78,107,80,108,81,110,86,111 91,113,92,114,106,114,110,113,111,112,115,109,119,105,122,99,122,82,121,81,120,79,119,78,118,76,117,75,117,74,114,74,111,77,109,78,107,81,106,83 106,84,105,87,104,89,104,111,105,113,107,115,108,117,113,119,114,119,115,120,118,121,125,121,125,120,126,119 e|********* m149,40 l149,44,148,45,144,53,144,54,143,55,142,57,142,60,141,61,141,67,143,69,147,70,162,70,162,72,161,75,159,76,157,80,155,81,153,84,152,86,148,89 147,91,145,92,139,98,138,100,138,105,141,108,145,110,163,110,165,109,167,107,169,107,171,105,172,105,173,104,173,103,174,102,174,100,172,98,171,95,171,94 170,93,169,91 e|********* m156,52 l156,97 e|********* m168,51 l168,57,169,61,170,63,170,67 e|********* m193,20 l188,25,187,27,183,31,181,36,179,38,179,39,180,40,185,40,190,39,195,37,196,36,199,34,201,34,201,33,204,33,207,35,209,36,210,38,212,40,213,42 214,43,214,46,213,47,212,49,211,50,209,51,209,52,208,53 e|********* m193,66 l193,64,195,62,197,59,204,52,207,50,208,49,210,48,211,48,214,46,215,45,217,45,218,44,220,43,225,43,227,45,228,47,228,62,227,63,226,65,224,67 223,69,221,71 e|********* m217,54 l217,55,214,59,213,60,213,61,212,64,211,66,211,67,210,69,210,70,209,71 e|********* m189,79 l190,79,192,78,193,77,196,76,197,76,199,75,200,74,202,74,203,72,204,72,206,71,207,69,208,69,210,68,211,67,214,67,214,66 e|********* m197,62 l197,70,196,73,194,76,193,77,193,82,192,83,191,86,190,87,190,98,191,99,192,101,197,103,200,105,204,106,215,106,216,105,224,103,226,102,227,102,228,101 230,100,233,97 e|********* m296,29 l295,30,293,34,291,41,288,47,284,54,280,60,277,66,276,70,276,72,275,73,274,75,274,76,273,77,272,79,272,80 e|********* m263,99 l263,107,261,109 e|********* m314,40 l313,41,310,46,307,52,302,58,298,64,293,70,289,75,286,80,285,81,284,83,284,84,283,85,282,87,282,90 e|********* m280,96 l280,102 e|********* m326,34 l326,43,325,47,323,53,320,59,318,65,316,70,313,75,309,79,308,81,307,82 e|********* m299,93 l299,94,300,96,300,97,301,98,302,100,303,101,303,103 e|********* m83,171 l96,174,115,175,210,175,228,173,241,170,252,168,261,165,271,160,280,156,288,153,298,150,310,146,334,142,345,140,353,139,358,137,361,136,359,136,355,138,347,140 327,142,313,144,300,146,286,149,273,151,262,153,254,155,249,156,248,157,247,157,246,158,246,159,252,159,259,158,267,154,277,151,285,147,295,143,305,138,313,135 327,129,333,126,338,124,339,123,357,123,356,124,353,130,351,132,349,135,348,136,347,138,347,139,346,140,345,140,345,148,343,148,342,149,339,149,334,154,331,156 329,157,327,159,325,160,324,160,323,161,337,161,344,160,350,159,354,158,360,157,366,157,366,156 e|********* m353,148 l350,158,350,167,352,169,357,169,362,168,366,167,367,166,369,165,370,163,371,162,371,161,372,161,373,160,373,161,374,162,375,165,375,167,376,168,377,168,377,170 378,170,378,171 e|********* m370,146 l371,147,372,147,373,148,373,149,374,149 e|********* m379,150 l381,150 e[/whitepad]
阿牛 发表于 2009-10-20 01:40:15 | 显示全部楼层
[whitepad]***400;200;400,200;;#c00;3.75; m110,61 l105,61,104,60,102,60,101,59,100,59,99,58,98,58,97,57,74,57,73,58,69,58,68,59,67,59,66,60,64,60,64,61,63,62,61,62,61,63,60,65 59,66,58,68,57,69,57,70,56,71,56,73,55,74,55,76,54,79,53,79,53,81,52,83,52,108,53,110,53,115,54,115,55,116,55,118,59,122,59,123 61,123,62,124,63,124,63,125,65,126,94,126,94,125,96,125,96,124,97,123,98,123,98,99 e|********* m85,98 l99,98,100,99,111,99 e|*******blue;* m159,82 l139,82,138,83,137,83,136,84,136,85,135,86,135,88,134,88,134,116,136,118,139,118,139,119,158,119,158,118,160,118,160,117,161,117,162,116,164,116,165,115 167,115,167,113,168,113,168,111,170,110,170,91,169,91,169,89,168,89,168,86,167,86,167,83,166,83,166,82,165,82,165,81,155,81 e|*******#600;* m203,116 l203,117,201,117,200,116,199,116,198,115,197,115,197,114,196,114,195,113,195,112,194,112,193,111,193,109,192,109,192,107,191,106,191,81,192,81,192,80,216,80 217,81,218,81,220,83,222,83,222,85,223,85,224,86,224,87,225,88,225,117,203,117 e|*******#090;* m251,44 l251,120,250,120,250,119,248,117 e|********* m242,43 l251,43,253,44,254,45,264,45,265,46,267,46,268,47,270,47,272,49,274,50,275,50,278,53,279,53,281,54,281,55,282,56,283,58,285,60,286,62,287,63 288,65,288,67,289,69,290,70,290,81,291,82,291,105,290,105,290,106,289,107,287,108,286,109,286,110,283,113,282,113,282,114,281,115,279,115,278,116,278,117 275,117,274,118,273,118,273,119,270,119,269,118,248,118 e|*******red;* m154,152 l155,152,156,153,156,154,158,154,158,155,160,155,160,156,162,156,162,157,165,157,166,158,197,158,197,155,199,155,199,152,200,152,200,146,201,146 e|********* m147,101 l154,101 e|********* m203,100 l204,100,204,98,207,98 e|********* m172,134 l179,134 e|********* m354,49 l354,50,353,51,352,53,352,56,351,57,350,60,348,63,347,66,346,68,345,71,340,81,338,83,337,83,337,85,335,87,335,88,334,89,333,89,333,91,332,91 332,93 e|********* m328,110 l328,114 e[/whitepad]
mlg4055748 发表于 2009-10-21 21:01:55 | 显示全部楼层
ding..........................................
匿名  发表于 2009-10-24 11:51:19
{:1_134:}
查看源文件 发表于 2009-10-26 16:23:15 | 显示全部楼层
ding....................................................
zhouwei1313 发表于 2009-10-30 21:26:36 | 显示全部楼层
好好好好好好好好好好
wei52hua 发表于 2009-11-2 14:37:43 | 显示全部楼层
这种灯很好哦{:1_128:}
monkey0357 发表于 2009-11-4 15:03:15 | 显示全部楼层
怎莫没有内容啊!!!!
chenzheng 发表于 2009-11-6 07:57:42 | 显示全部楼层
hxw2009 发表于 2009-11-8 17:06:19 | 显示全部楼层
漂亮啊!!!!!!!!!!!!!!!!!!!!
千里漂 发表于 2009-11-9 23:02:07 | 显示全部楼层
好看,实用!
{:1_118:}
sanbaihuo 发表于 2009-11-13 00:18:16 | 显示全部楼层
学习。。。。。。。。。。。。。。。。。。。。。。。。
qaz1165937 发表于 2009-11-14 08:40:54 | 显示全部楼层
建议版主注意下恶意灌水的人{:1_137:}
xinze 发表于 2009-11-23 20:13:21 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ywh606 发表于 2009-11-28 19:57:30 | 显示全部楼层
soloomi 发表于 2009-12-12 10:12:42 | 显示全部楼层
学习啦,学习中........
广告中人 发表于 2009-12-16 08:28:23 | 显示全部楼层
支持、、、、、、、、、、、、、、、
xzv2869 发表于 2009-12-16 21:35:00 | 显示全部楼层
好好好好好好好好好好
广告中人 发表于 2009-12-17 09:31:12 | 显示全部楼层
好支持、、、、、、、、、
学习了
xzv2869 发表于 2009-12-19 19:42:35 | 显示全部楼层
不错。我佩服,学习了
xuejiangju 发表于 2009-12-21 16:52:54 | 显示全部楼层
我红灯都是100颗一组!
huanrijian 发表于 2009-12-25 12:08:27 | 显示全部楼层
好评ddddddddddddddddddddddddddddddddd
lubingbing 发表于 2009-12-29 23:34:20 | 显示全部楼层
回25,这个双色灯还是不同于红灯的,坛主不说了嘛,最佳50-75个。。
价格坛主的店里,,想知道的去看看吧,有好几种双色灯呢。。我就在这买的。
匿名  发表于 2010-1-3 18:09:58
{:1_125:}{:1_135:}{:1_141:}{:1_124:}
zhangweijun 发表于 2010-1-4 01:14:59 | 显示全部楼层
来了就学点东西啊!!!!!!!!!!!!!
zhangweijun 发表于 2010-1-4 01:18:32 | 显示全部楼层
请问坛主,这种控制器可以渐变不?
GMT+8, 2024-5-3 23:49
