查看: 2185|回复: 4
望高手解答
342508857 发表于 2009-6-21 01:06:53 | 显示全部楼层 |阅读模式
本人有一单色条屏,因为数据线不见了,现在想自己做一跟数据线
请教高手告诉我接线顺序,谢谢
是P625
恒光灯箱 发表于 2009-6-21 11:37:26 | 显示全部楼层
买两个9针的串口插头,根据你的卡,一般用公头,然后将两个串口头的2、3、5用三根线直接连接起来,可以用网线,如不行就将一头的2、3两根线交换一下!
 楼主| 342508857 发表于 2009-6-21 14:47:47 | 显示全部楼层
{:1_137:}谢谢,我先试下,
jxsh 发表于 2009-6-21 17:14:51 | 显示全部楼层
学习学习
高手就是高手啊
热风 发表于 2009-7-9 01:30:12 | 显示全部楼层
[whitepad]***400;200;400,200;;** m18,48 l18,47,19,46,21,45,22,45,23,44,25,43,42,43,43,45,44,46,44,47,45,49,45,51,44,53,42,55,41,57,37,61,35,62,33,64,31,65,30,66 28,67,27,67,26,68,24,69,23,69,22,70,21,70,19,71,18,71,17,72,18,73,35,73,37,74,41,74,42,75,49,75 e|********* m64,70 l66,70,67,71,69,71,70,73,72,74,73,76,74,77,74,78,75,78,75,79,76,79 e|********* m95,34 l96,34,96,33,104,33,106,34,112,34,114,35,115,36,116,36,118,37,119,38,120,38,121,40,122,41,122,44,121,45,119,46,117,48,115,48,113,50,111,51 118,51,119,52,120,52,120,53,121,54,121,55,122,56,123,58,123,64,122,65,121,67,121,68,120,69,119,71,118,72,116,73,115,74,114,74,112,75,111,76 110,76,108,77,106,77,104,78,91,78,89,76,88,76,86,74,86,73,84,71 e|********* m132,77 l132,79,134,80,136,82,136,83,137,83,137,84,138,84,138,85 e|********* m173,32 l173,35,172,37,172,41,171,42,170,44,170,45,169,46,168,48,167,49,167,50,166,52,165,53,165,54,164,54,164,55 e|********* m158,59 l160,58,161,57,162,57,164,56,165,55,167,55,169,53,181,53,182,54,184,55,185,56,187,57,187,59,189,61,189,71,187,73,186,75,185,75,184,76,182,77 181,77,180,78,178,79,165,79,163,77,161,76,160,76,159,75,157,74,156,72,155,71 e|********* m167,40 l168,39,176,39,177,38,179,37,187,37 e|********* m215,29 l215,32,217,33,219,35,223,36,253,36,254,35,257,34,259,33,263,33,264,32,266,31,267,30,268,30,270,29,271,28,273,28,273,27,274,27,274,26 e|********* m262,12 l261,13,261,14,258,18,257,23,256,24,256,26,255,27,254,31,254,35,253,37,252,38,251,41,251,43,249,45,249,48,246,51,246,52,244,54 e|********* m225,42 l229,46,232,48,233,50,235,51,240,61,240,62,241,66,242,68,242,76,243,78,243,85,242,84 e|********* m241,51 l242,50,244,50,248,49,249,48,251,47,256,47,258,45,261,45,261,46,263,48,263,49,264,51,265,54,265,76,263,78,263,84,262,85,261,87,261,88 e|********* m240,52 l242,52,243,53,245,54,246,54,248,55,249,56,256,56 e|********* m243,62 l244,62,245,63,249,63,250,64,261,64 e|********* m250,69 l251,69,252,70,260,70 e|********* m213,87 l283,87 e|********* m285,39 l288,39,290,38,292,36,294,36,296,34,298,34,299,33,301,32,302,32,302,31,304,30,305,30,307,28,310,28,311,27,311,26,314,26,314,25,315,24,320,24 322,23,322,22,323,22 e|********* m309,16 l309,19,308,21,307,24,307,25,306,28,305,29,305,31,303,33,302,35,302,45,303,46,308,46,310,45,312,43,315,43,317,42,319,40,322,40 e|********* m293,66 l294,65,299,65,302,64,303,63,306,63,308,62,309,61,311,60,312,60,313,59,315,58,316,58,317,57,319,57,321,55,323,55,325,53,327,53,328,52,328,51 e|********* m310,33 l310,52,311,56,311,69 e|********* m276,46 l280,46,281,47,283,48,284,48,285,49,287,50,288,51,290,52,292,54 e|********* m278,60 l286,60,288,61,289,62,291,63,294,66,295,68,295,70,293,72,293,73,292,73,292,74,290,75,289,75,290,76,293,77,299,80,300,81,302,81,306,83,307,84 311,84,312,85,316,85,318,86,338,86,340,85,342,83,344,82,345,81,346,81,349,78,349,77,350,77,350,76 e[/whitepad]
GMT+8, 2024-5-10 00:35
