查看: 1469|回复: 0
基于TMP302型号的引脚可选跳变点、工作电压为 1.4V 的温度开关系列
拍明芯城 发表于 2018-10-24 16:08:40 | 显示全部楼层 |阅读模式
  The TMP302 is a temperature switch in a micropackage (SOT563). The TMP302 offers low power (15 µA maximum) and ease-of-use through pin-selectable trip points and hysteresis.
  These devices require no additional components for operation; they can function independent of microprocessors or microcontrollers.
  The TMP302 is available in several different versions. For additional trip points, contact a TI representative.
  Low Power: 15 µA (maximum)
  SOT563 Package: 1.6-mm × 1.6-mm × 0.6 mm
  Trip-Point Accuracy: ±0.2°C (typical)
  From +40°C to +125°C
  Pin-Selectable Trip Points
  Open-Drain Output
  Pin-Selectable Hysteresis: 5°C and 10°C
  Low Supply Voltage Range: 1.4 V to 3.6 V
  APPLICATIONS
  Cell Phone Handsets
  Portable Media Players
  Consumer Electronics
  Servers
  Power-Supply Systems
  DC-DC Modules
  Thermal Monitoring
  Electronic Protection Systems
  关于TI品牌其它产品信息https://www.iczoom.com/brand/509-c-1-20.html
GMT+8, 2024-5-6 14:13
