查看: 893|回复: 0
基于UCC24610 型号的二次侧同步整流器控制器
拍明芯城 发表于 2018-8-29 17:15:11 | 显示全部楼层 |阅读模式
  This GREEN Rectifier controller is a high-performance controller and driver for standard and logic-level N-channel MOSFET power devices used for low-voltage secondary-side synchronous rectification.
  The combination of controller and MOSFET emulates a near-ideal diode rectifier. This solution not only directly reduces power dissipation of the rectifier but also indirectly reduces primary-side losses as well, due to compounding of efficiency gains.
  Using drain-to-source voltage sensing, the UCC24610 is ideal for Flyback and LLC-resonant power supplies but can also be used with other power architectures. The UCC24610 is optimized for output voltages from 4.5 V to 5.5 V, and is suitable for use with lower and higher output voltages as well.
  The UCC24610 offers a programmable false-triggering filter, a programmable timer to automatically switch to light-load mode at light load, and a SYNC input for optional use in continuous conduction mode (CCM) systems. Protection features on TON and EN/TOFF pins prevent run-away on-time due to open-circuit or short-circuit fault conditions.
  This device is available in an 8-pin SOIC package and an 8-pin, 3.0-mm × 3.0-mm SON package with an exposed thermal pad.
  Secondary-Side Controller Optimized for 5-V Systems
  Up to 600-kHz Operating Frequency
  VDS MOSFET-Sensing
  1.6-Ω Sink, 2.0-Ω Source Gate-Drive Impedances
  Micro-Power Sleep Current for 90+ Designs
  Automatic Light-Load Management
  Synchronous Wake-Up From Sleep and Light-Load Modes
  Protection Features on Programming Inputs
  SYNC Input for CCM Operation
  20-ns Typical Turnoff Propagation Delay
  Improved Efficiency and Design Flexibility Over Traditional Diode Solution
  May Be Biased Directly From 5-V Output
  Minimal Component Count
  APPLICATIONS
  AC-to-DC 5-V Adapters
  5-V Bias Supplies
  Low Voltage Rectification Circuits
  Flyback and LLC Converters
  相关终端应用
  Circuit Breaker
  Data Encoders/Decoders
  Distribution Amplifiers
  Drone Accessories
  EV 基础设施 - 1&2 EVSE
  Electronic Warfare
  HDTV
  LCD 测试设备
  LED 驱动器
  Relay AC Analog Input Module
  Relay Power Supply Module
  Up/Down/Cross Conversion
  一体式打印机
  三相 UPS
  交流/直流功率计和分析器
  交流电源、直流电源和电子负载
  产妇和新生儿护理监视器
  仪表(实验室、分析、现场)
  保护继电器 - 特殊功能
  内存和半导体测试设备
  出口和紧急照明
  功率传输单元
  医疗 PSU
  单相 UPS
  变电站自动化 - IEC61850 过程总线
  台式计算机/主板
  商用 DIN 导轨电源
  商用电池充电器
  商用网络和服务器 PSU
  工业 AC-DC
  平板电脑:多媒体
  无线通信测试设备
  普通笔记本电脑
  智能手机
  标准打印机
  电器电池充电器
  电子病床和床控制器
  电池测试设备
  电视电源
  直流充电()
  示波器 (DSO)
  移动壁式充电器设计
  超高清 4K OLED 电视
  超高清 LCD 电视
  远程保健系统
  适用于广播的布线和传输系统
  配电自动化 - 终端设备
GMT+8, 2024-5-19 08:13
