查看: 598|回复: 0
基于TL431A型号的精度为 1% 的可调精密并联稳压器
拍明芯城 发表于 2018-8-29 17:08:26 | 显示全部楼层 |阅读模式
  The TL431 and TL432 devices are three-terminal adjustable shunt regulators, with specified thermal stability over applicable automotive, commercial, and military temperature ranges. The output voltage can be set to any value between Vref (approximately 2.5 V) and 36 V, with two external resistors. These devices have a typical output impedance of 0.2 Ω. Active output circuitry provides a very sharp turn-on characteristic, making these devices excellent replacements for Zener diodes in many applications, such as onboard regulation, adjustable power supplies, and switching power supplies. The TL432 device has exactly the same functionality and electrical specifications as the TL431 device, but has different pinouts for the DBV, DBZ, and PK packages.
  Both the TL431 and TL432 devices are offered in three grades, with initial tolerances (at 25°C) of 0.5%, 1%, and 2%, for the B, A, and standard grade, respectively. In addition, low output drift versus temperature ensures good stability over the entire temperature range.
  The TL43xxC devices are characterized for operation from 0°C to 70°C, the TL43xxI devices are characterized for operation from 40°C to 85°C, and the TL43xxQ devices are characterized for operation from 40°C to 125°C.
  Reference Voltage Tolerance at 25°C
  0.5% (B Grade)
  1% (A Grade)
  2% (Standard Grade)
  Adjustable Output Voltage: Vref to 36 V
  Operation From −40°C to 125°C
  Typical Temperature Drift (TL431B)
  6 mV (C Temp)
  14 mV (I Temp, Q Temp)
  Low Output Noise
  0.2-Ω Typical Output Impedance
Sink-Current Capability: 1 mA to 100 mA
  相关料号推荐:TL431ATA
  相关终端应用
  AV 接收器
  CPAP 呼吸机
  Drone Accessories
  HDTV
  HVAC 系统控制器(大型商用)
  HVAC 阀门和泵控制
  IP 电话
  IP 网络摄像机
  LED 驱动器
  Relay Power Supply Module
  Thermal Imaging Camera
  WLAN/WiFi 接入点
  X 射线系统
  专业扬声器系统
  专业音频放大器(机架式)
  专业音频混合器/控制平面
  书架立体声音响系统
  交流电源、直流电源和电子负载
  交流逆变器和 VF 驱动器
  交流驱动器电源模块
  产妇和新生儿护理监视器
  伺服驱动器电源模块
  体外诊断
  体外除颤器
  健身器
  内窥镜
  冰箱和冰柜
  制造机器人
  助听器
  医疗 PSU
  占位检测(人员跟踪、人数计数)
  可再生能源存储 - 铅酸电池管理器
  可穿戴健身设备和活动监视器
  可视门铃
  吉他放大器和其他乐器放大器
  咖啡机
  商用 DC-DC
  商用 DIN 导轨电源
  商用电池充电器
  园区和分支交换机
  多参数患者监护仪
  太阳能 - 微型逆变器
  太阳能 - 组串式逆变器
  太阳能 - 能量优化器
  宏远程无线电单元 (RRU)
  室内照明
  家用水泵和风扇
  小型蜂窝基站
  工业 AC-DC
  平板电脑:多媒体
  心电图 (ECG)
  无管式空调室内系统
  无管式空调室外装置
  无线患者监视器
  无线通信测试设备
  普通笔记本电脑
  智能仪表 - 电表
  智能手机
  有源天线系统 mMIMO (AAS)
  有线控制
  气体检测器
  油烟机
  洗碗机
  洗衣机和干衣机
  混料器、搅拌器和食品加工机
  温度调节装置
  漏水检测仪
  激光测距
  火警控制面板 (FACP)
  灯泡和灯管
  热水器和加热系统
  烹饪灶具
  照明:LCD 背光
  用于 HMI POS 的单板计算机
  电动牙刷
  电器电池充电器
  电子病床和床控制器
  电源:电池管理
  电网通信基础设施 - 数据集中器
  电视电源
  移动壁式充电器设计
  移动电源
  空气净化器和加湿器
  编码器和解码器
  胰岛素泵
  脉动式血氧计
  血压监护仪
  血糖监护仪
  访问控制 HMI 键盘
  超声波扫描仪
  超高清 4K OLED 电视
  超高清 LCD 电视
  输液泵
  远程保健系统
  透析器
  配电自动化 - 终端设备
  钢琴、键盘和合成器
  键盘
  门键盘和阅读器
  陆防:无线电设备
  风扇
  麻醉释放系统
GMT+8, 2024-5-10 00:02
