查看: 704|回复: 0
基于LM4041A12型号 1.2V 精密微功耗并联电压参考,0.1% 精确度
拍明芯城 发表于 2018-8-29 17:05:45 | 显示全部楼层 |阅读模式
  The LM4041 series of shunt voltage references are versatile, easy-to-use references suitable for a wide array of applications. They require no external capacitors for operation and are stable with all capacitive loads. Additionally, the reference offers low dynamic impedance, low noise, and a low temperature coefficient to ensure a stable output voltage over a wide range of operating currents and temperatures. The LM4041 uses fuse and Zener-zap reverse breakdown voltage trim during wafer sort to offer four output voltage tolerances, ranging from 0.1% (max) for the A grade to 1% (max) for the D grade. Thus, a great deal of flexibility is offered to designers in choosing the best cost-to-performance ratio for their applications. The LM4041 is available in a fixed (1.225 V nominal) or an adjustable version (which requires an external resistor divider to set the output to a value between 1.225 V and 10 V).
  Packaged in space-saving SC-70 and SOT-23-3 and requiring a minimum current of 45 µA (typ), the LM4041 also is ideal for portable applications. The TO-92 package also is available for through-hole packaging needs. The LM4041xI is characterized for operation over an ambient temperature range of -40°C to 85°C. The LM4041xQ is characterized for operation over an ambient temperature range of -40°C to 125°C.
  1.225-V Fixed and Adjustable Outputs (1.225 V to 10 V)
  Tight Output Tolerances and Low Temperature Coefficient
  Max 0.1%, 100 ppm/°C — A Grade
  Max 0.2%, 100 ppm/°C — B Grade
  Max 0.5%, 100 ppm/°C — C Grade
  Max 1.0%, 150 ppm/°C — D Grade
  Low Output Noise . . . 20 µVRMS (Typ)
  Wide Operating Current Range . . . 45 µA (Typ) to 12 mA
  Stable With All Capacitive Loads; No Output Capacitor Required
  Available in
  Industrial Temperature: -40°C to 85°C
  Extended Temperature: -40°C to 125°C
  Applications
  Data-Acquisition Systems
  Power Supplies and Power-Supply Monitors
  Instrumentation and Test Equipment
  Process Control
  Precision Audio
  Automotive Electronics
  Energy Management/Metering
Battery-Powered Equipment
  相关料号推荐:LM4041DYM3-1.2-TR
  相关终端应用
  Circuit Breaker
  三相 UPS
  交流电源、直流电源和电子负载
  冰箱和冰柜
  割草机
  医疗 PSU
  单相 UPS
  吸尘器
  咖啡机
  商用 DC-DC
  商用 DIN 导轨电源
  商用电信整流器
  商用电池充电器
  商用网络和服务器 PSU
  太阳能 - 微型逆变器
  太阳能 - 组串式逆变器
  家用水泵和风扇
  家电压缩机
  工业 AC-DC
  无管式空调室内系统
  无管式空调室外装置
  无绳手持园艺工具
  无绳电动工具
  服务型机器人
  机器人割草机
  油烟机
  洗衣机和干衣机
  混料器、搅拌器和食品加工机
  由市电供电的工具
  电子病床和床控制器
  真空机器人
  风扇
GMT+8, 2024-5-19 07:49
