查看: 612|回复: 0
基于LM4040-N型号的100ppm/C 精密微功耗并联电压基准
拍明芯城 发表于 2018-8-29 17:04:31 | 显示全部楼层 |阅读模式
  Ideal for space-critical applications, the LM4040-N precision voltage reference is available in the sub-miniature SC70 and SOT-23 surface-mount package. The advanced design of the LM4040-N eliminates the need for an external stabilizing capacitor while ensuring stability with any capacitive load, thus making the LM4040-N easy to use. Further reducing design effort is the availability of several fixed reverse breakdown voltages: 2.048 V, 2.5 V, 3 V, 4.096 V, 5 V, 8.192 V, and 10 V. The minimum operating current increases from 60 µA for the 2.5-V LM4040-N to 100 µA for the 10-V LM4040-N. All versions have a maximum operating current of 15 mA.
  The LM4040-N uses a fuse and Zener-zap reverse breakdown voltage trim during wafer sort to ensure that the prime parts have an accuracy of better than ±0.1% (A grade) at 25°C. Bandgap reference temperature drift curvature correction and low dynamic impedance ensure stable reverse breakdown voltage accuracy over a wide range of operating temperatures and currents.
  Also available is the LM4041-N with two reverse breakdown voltage versions: adjustable and 1.2 V. See the LM4041-N data sheet (SNOS641).
  SOT-23 AEC Q-100 Grades 1 and 3 available
  Small Packages: SOT-23, TO-92, and SC70
  No Output Capacitor Required
  Tolerates Capacitive Loads
  Fixed Reverse Breakdown Voltages of 2.048 V, 2.5 V, 3 V, 4.096 V, 5 V, 8.192 V, and 10 V
  Key Specifications (2.5-V LM4040-N)
  Output Voltage Tolerance (A Grade, 25°C): ±0.1% (Maximum)
  Low Output Noise (10 Hz to 10 kHz): 35 µVrms (Typical)
  Wide Operating Current Range: 60 µA to 15 mA
  Industrial Temperature Range: 40°C to 85°C
  Extended Temperature Range: 40°C to 125°C
  Low Temperature Coefficient: 100 ppm/°C (Maximum)
  相关料号推荐:LM4040DYM3-4.1-TR
  相关终端应用
  Aircraft Engine Control/Monitoring
  Circuit Breaker
  Compact Relay
  EV Charging Station Power Module
  EV 基础设施 - 1&2 EVSE
  HVAC 阀门和泵控制
  HVAC 风机电机控制
  Relay AC Analog Input Module
  三相 UPS
  交流电源、直流电源和电子负载
  交流逆变器和 VF 驱动器
  保护继电器 - 特殊功能
  制造机器人
  功率传输单元
  单相 UPS
  变电站自动化 - IEC61850 过程总线
  商用 DIN 导轨电源
  商用电信整流器
  商用电池充电器
  太阳能 - 微型逆变器
  太阳能 - 组串式逆变器
  接触器
  断路器 - 电力断路器 (LV/MV)
  无刷直流电机驱动器
  电池测试设备
  直流充电()
  自动化机械:注塑成型机
  配电自动化 - 终端设备
  铁路运输 - 电机和致动器控制
GMT+8, 2024-5-9 17:15
