查看: 5196|回复: 15
怎么用万用表测量一串灯需要加多少电阻?
red521led 发表于 2009-5-7 14:33:28 | 显示全部楼层 |阅读模式
怎么用万用表测量一串灯需要加多少电阻?
 楼主| red521led 发表于 2009-5-7 14:36:12 | 显示全部楼层
能不能不查灯的个数,直接用万用表连接在两端测量 然后计算出应该增加多少电阻值
cdc8023 发表于 2009-5-12 22:44:33 | 显示全部楼层
学习……路过了……我也想知道
 楼主| red521led 发表于 2009-5-15 15:21:40 | 显示全部楼层
量电压是不是要先接通电源啊
是不是要先接上若干电阻再接电源呢,如果不接电阻就把电源接上了,电流过大不就烧灯了吗?
哎 自学问题多啊
sjbtl5555 发表于 2009-5-17 11:50:41 | 显示全部楼层
我也在自学,要问的问题太多了。还是自己研究吧
henguang 发表于 2009-5-25 14:19:44 | 显示全部楼层
不想数灯,就买个灯箱测试仪.挺方便的
xusuwu 发表于 2009-7-2 00:50:08 | 显示全部楼层
自学问题多啊                                                 [whitepad]***400;200;400,200;;** m87,41 l87,42,88,45,88,142 e|********* m101,36 l114,36,138,40,144,42,149,43,155,45,156,46,162,46,165,47,169,49,173,50,177,52,180,53,185,55,189,56,194,60,199,62,202,64,205,65,207,67,208,67 208,95,206,103,205,109,205,115,203,119,202,124,202,127,201,128,201,131,200,132,200,133,199,133,199,134,198,134,198,135,197,136,197,137,196,138,196,141,195,143 195,146,194,148,194,157,193,158,193,160,192,160 e|********* m98,70 l123,70,133,71,142,72,149,74,150,74,147,77,142,87,142,88,141,89,141,90,140,90,140,91,139,91,139,93,138,94,138,105,139,103,141,100,143,98,147,96 150,93,152,92,156,92,157,93,158,95,159,96,159,99,148,99,145,100,135,100 e|********* m288,18 l289,21,291,25,292,28,292,33 e|********* m247,29 l247,31,251,32,259,35,271,36,284,39,298,42,308,45,316,48,320,49,321,50,320,50,318,49,315,49,311,47,305,47,297,45,291,45,285,43 e|********* m281,44 l281,49,282,52,282,66,286,66,288,65 e|********* m245,62 l242,63,243,63,249,65,259,68,269,72,279,75,288,79,292,81,293,82,286,82,284,84,283,88,281,91,278,103,276,109,273,112,272,112,272,107,273,107,281,103 287,101,294,100,302,100,305,98,310,98,310,107,309,108,306,109,291,109,288,107,285,106,283,105,283,104,284,103,286,102,289,102 e|********* m207,130 l208,130,209,132,213,136,215,139,218,143,223,146,230,152,250,162,261,166,272,171,286,175,296,178,304,181,316,181,317,180,317,176,315,172,313,167,309,161 e|********* m297,147 l299,147,308,150,316,153,326,157,338,163,349,169,357,173,367,177,372,181,375,183,376,184,376,186,374,187,366,187,360,185,351,185,319,177,295,165,285,159 e|********* m281,106 l305,106,305,105 e|********* m306,57 l303,57,300,58,295,60,291,61,285,62,279,64,274,65,271,68,268,70 e[/whitepad]
yuxinworld 发表于 2009-7-16 08:41:24 | 显示全部楼层
我说下不知对不对,如果不对的,请懂的指正!先看有多少个灯珠,按一个灯珠的额定电压,每个的电压*灯珠数=这一路的电压,然后用接过来的电压减去这一路的电压得的到数字(电阻应该分担的电压)再除以10~20毫安(灯珠允许的电流),就是应该接的电阻值!
无眠渺岩 发表于 2009-7-16 14:56:21 | 显示全部楼层
我觉得楼上说的对—————————————
qqsw 发表于 2009-7-27 01:16:09 | 显示全部楼层
9楼。。有心人。。。。回答正确。。。{:1_137:}
wy2005 发表于 2009-7-27 18:30:46 | 显示全部楼层
有现成的公式,不用另多一举吧?
wy2005 发表于 2009-7-27 18:52:10 | 显示全部楼层
请问高手:我用3只2k/5w的电阻替代6只1k2w的,电阻摸上去发烫,有问题否?灯箱已装好,(担心!!)
sswbchj 发表于 2011-2-6 22:10:51 | 显示全部楼层
kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
吕凹良 发表于 2011-4-17 23:58:00 | 显示全部楼层
随着互联网科技的发展,电脑上出现了越来越多的实用性和专业性很强的各色软件,它们帮助我们在计算机或是互联网上完成了许多的工作,帮助我们既方便又快捷的完成我们的工作,可是在我们下载这些软件的时候,往往会面临一个选择性的难题,在互联网上有许多的提供软件下载的地方,如何选择最安全的,最全面的,最新的我们需要的软件呢,我们需要一个常用软件下载的集大成者,于是我们将目光转向了谷普下载。
  谷普下载是一个专门提供各类下载的网站,并且谷普下载所提供的各类下载程序全部都是免费的,并且更新的相当的快。对于我们常用到的一些软件,谷普下载将他们进行了分类,谷普下载的下载栏里有网络软件下载、系统工具下载、应用软件下载、聊天工具下载、图形图像工具下载、多媒体类的软件下载、行业软件下载、编程开发软件下载和教育教学软件的下载。如此细致,种类繁多的应用软件下载分类不但让需要应用软件的朋友们找起来相当的方便,同时对于那些许多需要各种不同种类的应用软件的朋友们来说,只需一个网站,全部都可以帮你搞定,而不再需要你去一个个的搜索和挑选,然后一个个的分开下载,这样节省了不少的时间,同时还保证了每款应用软件的最新版本和很高的安全性。 谷普下载 www.gpxz.com
小翰林 发表于 2011-12-18 21:16:50 | 显示全部楼层
计算一下,不过还有压降!
1973085100 发表于 2012-1-23 19:28:05 | 显示全部楼层
        我觉得  最好的配置电阻的方法还是用LED电子灯箱测试仪配置电阻﹐将电流控制在15-20MA之内,再决定电阻阻值,建议电流不高于18MA,虽然20MA也在正常范围内,但电流过大,光衰快,不利于led灯的使用寿命。
       具体的操作:使用前将电子灯箱测试仪拨档开关置于复位档,然后将红色(正极)鱼夹接在发光二级管或灯串的正极;将黑色(负极)鱼夹接在发光二极管的负极,打开电源开关将拨档开关逐档旋向10K、9K、8K…这时电子灯箱 测试仪面板上屏幕显示值在15_20MA时拨档开关所对应的数值就是限流电阻的配比值。完事将拨档开关置于复位档。
GMT+8, 2024-5-6 19:41
