查看: 756|回复: 0
泰德TD14102A 380kHz 20V PWM降压型DC/DC变换器
拍明芯城 发表于 2018-7-26 17:53:37 | 显示全部楼层 |阅读模式
  TD1410 2A 380KHz 20V PWM Buck DC/DC Converter
  The TD1410 is a 380 KHz fixed frequency monolithic step down switch mode regulator with a built in internal Power MOSFET. It achieves 2A continuous output current over a wide input supply range with excellent load and line regulation.The device includes a voltage reference, oscillation circuit, error amplifier, internal PMOS and etc.The PWM control circuit is able to adjust the duty ratio linearly from 0 to 100%. An enable function, an over current protection function and a short circuit protection function are built inside. An internal compensation block is built in to minimize external component count.The TD1410 serves as ideal power supply units for portable devices.
  Features
  * 2A Constant Output Current
  * 140mΩ RDSON Internal Power PMOSFET Switch
  * Up to 95% Efficiency
  * Fixed 380KHz Frequency
  * Wide 3.6V to 20V Input Voltage Range
  * Output Adjustable from 1.222V to 18V
  * Built in Frequency Compensation
  * Built in Thermal Shutdown Function
  * Built in Current Limit Function
  * SOP-8 Package is Available
  * The minimum dropout up to 0.3V
  Applications
  * Portable DVD
  * LCD Monitor / TV
  * Battery Charger
  * ADSL Modem
  * Telecom / Networking Equipment
型号:TD1501S50               品牌:泰德
型号:TD1410                    品牌:泰德
型号:PT4515CETOW         品牌:华润矽威
型号:PT4501DE23C          品牌:华润矽威
型号:PT4501DESOH         品牌:华润矽威
型号:PT4205E89E             品牌:华润矽威
型号:PT4203E23E             品牌:华润矽威
型号:PT4115EE89E           品牌:华润矽威
型号:PT4115B89E            品牌:华润矽威
型号:PT4115B89E-B         品牌:华润矽威
GMT+8, 2024-5-1 23:48
