TD6810 1.5MHz 800mA Synchronous Step-Down Regulator Dropout
The TD6810 is a high efficiency monolithic synchronous buck regulator using a constant frequency, current mode architecture. The device is available in an adjustable version and fixed output voltages of 1.5V and 1.8V. Supply current during operation is only 20mA and drops to ≤1mA in shutdown. The 2.5V to 5.5V input voltage range makes the TD6810 ideally suited for single Li-Ion battery-powered applications. 100% duty cycle provides low dropout operation, extending battery life in portable systems.Automatic Burst Mode operation increases efficiency at light loads, further extending battery life.Switching frequency is internally set at 1.5MHz, allowing the use of small surface mount inductors and capacitors.The internal synchronous switch increases efficiency and eliminates the need for an external Schottky diode. Low output voltages are easily supported with the 0.6V feedback reference voltage. The TD6810 is available in a low profile (1mm) TSOT23-5 package.
Features
* High Efficiency: Up to 96%
* High Efficiency at light loads
* Very Low Quiescent Current: Only 20uA During Operation
* 800mA Output Current
* 2.5V to 5.5V Input Voltage Range
* 1.5MHz Constant Frequency Operation
* No Schottky Diode Required
* Low Dropout Operation: 100% Duty Cycle
* 0.6V Reference Allows Low Output Voltages
* Shutdown Mode Draws ≤1uA Supply Current
* Current Mode Operation for Excellent Line and Load Transient Response
* Overtemperature Protected
* Low Profile (1mm) TSOT23-5 Package
Applications
* Cellular Telephones
* Personal Information Appliances
* Wireless and DSL Modems
* Digital Still Cameras
* MP3 Players
* Portable Instruments
型号:ME7138PG 品牌:ME
型号:ME6211C33M5G 品牌:ME
型号:ME6209A50PG 品牌:ME
型号:ME4054M5G 品牌:ME
型号:ME3116AM6G 品牌:ME
型号:ME2802A33M3G 品牌:ME
型号:ME2802A30M3G 品牌:ME
型号:ME2802A22M3G 品牌:ME
型号:TD6810 品牌:TD
型号:TD1501SADJ 品牌:TD
Iczoom拍明芯城(www.iczoom.com)聚焦于中小企业需求,具有货源可靠、品类齐全、交付及时、价格实惠、方案众多的特点和服务优势,客户来源非常丰富,原厂、代理商、正品经销商、同行电商、终端商均有注册。 Iczoom拍明芯城严格把控卖家资质和货品质量,快速匹配买卖信息,帮助客户“卖得快、买得全”。同时,Iczoom拍明芯城为中小企业提供专业的管理软件和全程供应链服务,让客户轻松实现内部的数据化管理。 |
