查看: 3594|回复: 0
聚诚推出全彩异步控制系统-全彩LED控制卡阿帕奇系列
笑问天 发表于 2014-6-2 22:53:23 | 显示全部楼层 |阅读模式
最新推出LED全彩异步嵌入式“阿帕奇,,播放器,异步方式独立工作控制显示屏,同时保持同步显示屏的高灰阶高刷新显示效果,全新搭载APACH〔勇士平台开创LED控制系统的全新应用理念。实现U盘设置屏体传输文件,外接温湿度、光感探测器,独有噪声探测显示功能,更大面积带载,更快数据传输,全面适用各类户内外全彩显示屏,引领LED显示系统向集成化一体化无线集群化全面实施。可通过网络与计算机连接,也可支持U盘、SD卡等存储介质,与接收卡连用控制显示屏。独立播放器可脱机流畅地播放几乎所有主流格式的视频文件;支持多种特技显示图片;支持文字透明滚动显示。可显示实时时钟和温度;支持自动亮度和音量调节;支持自动开关屏功能。自带网络连接功能,通过组网管理。配合管理软件用户轻松管理众多分布在不同区域的显示屏。可支持Win/Android/ios
Apachi, our newest full-colour LED screen asynchronous embedded Player.lt can control the screen independently in asynchronous
way.Meanwhile keeping high grey scale and high refresh rate effect as the synchronous LED screen.lt can use USB flash disk to setup the
screen and transfer files. Temperature sensor, humidity sensor and brightness sensor are accepted. And esspecially the noise detect data
can be display. APACHE can control larger area and transfer data quicker. It can be use in different kinds of indoor and outdoor full-color
LED screen. It lead LED control system to an integration and wireless clustering operation.APACHI can connect the PC through
network,also support USB flash disk and SD memory card.lt has to connect with receiving card together when controling LED screen.
APACHI can off-line playing almost all the format of vedio file. Special effect pictures and rolling transparent text are all supported.lt also
support displaying real time clock and temperature,automatic adjust brightness and volume, screen auto on/off. APACHI has network con-
necting function, it can be managed through networking.This function help users by using software to manage the screens which install in
different area. Win/Android/los system are all accepted.
GMT+8, 2024-5-10 16:36
